March 2, 2023 at 10:17 am
thanks for your reply
what is the max number of nodes and elements in ansys student?
the curing simulation can be enabled inside the transient thermal package on the upper left part of your screen...also with its installation in engineering data a, cure simulation data source is enabled without having to create the material manually... I get that you have ansys student in your pc..can you please see if you have theese options available?
I recommend for this problem that you watch the following youtube video, regardless if you answer me or not. It is very high quality and right to the point:
