March 2, 2023 at 11:17 am
If you're using a source term you're adding that amount of material at the defined rate. I'm not sure how that will interact with the static bed.
On the ALH there's the multiphase course, but that doesn't have anything on the fixed bed part - I'm just about to review the lecture, once I finish the DPM one and log off from here!
The advantage of the Community is that anyone or everyone can help, however that means we (staff) can't take any files or communicate in anyway other than here - it's noted (or was) in the rules you may have read when you registered.
