Hello, I've been having the same problem. Was doing eigenvalue buckling simulations (among other things) and had a few load multipliers of modes of buckling as output parameters. Was working fine, was able to change the geometry as parameters and recieve the output parameters. But then i wanted to change which mode of buckling was an output parameter and i started getting this error.
Have you found a solution?
