Praneeth
Thank you for reaching out to us and your patience is well appreciated.
Please go through the following observations / comments on your post:
  1. Did you change the convergence criterion from the default one? If so, please check with default convergence values and also share the screenshot for your model convergence.
  2. Validate your simulation setup for the correctness?
  3. Please go through examples and getting started guides on Q3D if you are a beginner.
Kindly share screenshots of the analysis setups to help us serve you better.
Best regards,
Praneeth.
