March 2, 2023 at 1:53 pm
Define Transient Analysis
NROPT, FULL
!Select all nodes
!Select all elements attached to the nodes
EKILL, ALL
!Plot ‘live elements’ (to check whether the Ekill command is executed, you may need to turn off the PowerGraphics
!Select EVERYTHING (Selects all activated and deactivated elements)
- constrain the deactivated elements if you want them to be born in the current configuration
- solve load step with killed elements
- If you now want to make the killed elements alive in next load step use EALIVE (???)
- remove constraints on dead elements as appropriate.
- solve
