March 2, 2023 at 3:02 pm
I want to check whether the outputs are within the convergence limit. I tried it following the adaptive convergence tutorial, but in my case (material defined as composite ACP), there isn't a convergence tool to track the refinement. When I use the same model (with homogeneous material), I can use a convergence tool. How can I perform a convergence study of my model with material as ACP composite? Is there any separate way for composite material?
Thank you
