Navya C
Hi Sana,
You need to use a double-sided rotor for your requirement, not a double-sided stator.
When you create a Maxwell model with that. Maxwell assumes the symmetry on the other side and assigns a symmetric multiplier of 2.
So, the Maxwell model is created with only one rotor and stator.
If you want to simulate the whole structure you can manually mirror the other stator and set it up manually.
Don't forget to put the symmetry multiplier to 1 in that case.
Navya
