March 2, 2023 at 5:26 pm
Hi Marufhossain,
Thank you for reaching out and your patience is much appreciated.
Is it the same case if you rerun the simulation?
Usually, if the simulation results are stored, your simulation will be complete in less time after rerunning it. And if that is not the case, it will take the normal simulation required for that model.
Did you do any modifications to the simulation model after a successful simulation? Then this might happen. Please share the screenshot of the items under the results category in the project manager window.
Best regards,
Praneeth.
