Hi Roy, it seems RMODIF cannot be used. Only a solution I can think of is to run multiple analysis and use solution combinations or append the result file using load case operations. Each analysis will differ in real constant properties only. The loads will vary their position in multiple loadsteps for each analysis. After analysing multiple cases, the result file can be created by appeanding results of desired loadstep from each analysis.
