Charlie Maurice
I ran with and without mpitest. with mpitest gives me the same thing, but the error I posted above as well (I can post that too if you think it would help). Not sure if its easier to see a pic or the actual output, so here are both:
c:\Users\cmaurice>set ANS_SEE_RUN=TRUE
c:\Users\cmaurice>set ANS_CMD_NODIAG=TRUE
c:\Users\cmaurice>"c:\Program Files\ANSYS Inc\v222\ansys\bin\winx64\ANSYS222.exe" -np 2 -dir c:\temp
 *** The AWP_ROOT222 environment variable is set to: C:\Program Files\ANSYS Inc\v222
 *** The AWP_LOCALE222 environment variable is set to: en-us
 *** The ANSYS222_DIR environment variable is set to: C:\Program Files\ANSYS Inc\v222\ANSYS
 *** The ANSYS_SYSDIR environment variable is set to: winx64
 *** The CADOE_DOCDIR222 environment variable is set to: C:\Program Files\ANSYS Inc\v222\CommonFiles\help\en-us\solviewer
 *** The CADOE_LIBDIR222 environment variable is set to: C:\Program Files\ANSYS Inc\v222\CommonFiles\Language\en-us
 *** The LSTC_LICENSE environment variable is set to: Ansys
 *** The P_SCHEMA environment variable is set to: C:\Program Files\ANSYS Inc\v222\AISOL\CADIntegration\Parasolid\PSchema
 *** The TEMP environment variable is set to: C:\Users\cmaurice\AppData\Local\Temp\17
 *** The PATH environment variable is set to: C:\Program Files\ANSYS Inc\v222\commonfiles\MPI\Intel\2021.5.0\winx64\libfabric\bin;C:\Program Files\ANSYS Inc\v222\commonfiles\MPI\Intel\2021.5.0\winx64\bin\release;C:\Program Files\ANSYS Inc\v222\commonfiles\MPI\Intel\2021.5.0\winx64\bin;C:\Program Files\ANSYS Inc\v222\ANSYS\bin\winx64\MPI\IntelMPI;C:\Program Files\ANSYS Inc\v222\ansys\bin\winx64\GPU\SIM;C:\Program Files\ANSYS Inc\v222\ansys\bin\winx64\BLAS\INTEL;C:\Program Files\ANSYS Inc\v222\tp\IntelCompiler\2019.5.281\winx64;C:\Program Files\ANSYS Inc\v222\tp\IntelMKL\2020.0.166\winx64;G☻C:\Program Files\ANSYS Inc\v222\aisol\bin\winx64;C:\Program Files\ANSYS Inc\v222\Framework\bin\Win64;C:\Program Files\ANSYS Inc\v222\tp\IntelCompiler\2019.5.281\winx64;C:\Program Files\ANSYS Inc\v222\tp\IntelMKL\2020.0.166\winx64;C:\Program Files\ANSYS Inc\v222\tp\hdf5\1.10.5\winx64;C:\Program Files\ANSYS Inc\v222\tp\qt_fw\5.5.1\Win64\bin;C:\Program Files\ANSYS Inc\v222\commonfiles\Stride\winx64;C:\Program Files\ANSYS Inc\v222\commonfiles\fluids\lib\winx64;[INSTALLDIR];C:\Program Files (x86)\Common Files\AspenTech Shared\;C:\Program Files\Rockwell Software\RSCommon;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\Citrix\HDX\bin\;C:\Program Files\Citrix\HDX\bin\;C:\Program Files\Citrix\Virtual Desktop Agent\;C:\Program Files (x86)\Internet Explorer;C:\Program Files\Ricardo\bin;C:\Program Files\Matlab 2022a\runtime\win64;C:\Program Files\Matlab 2022a\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI Foundation\VISA\Win64\Bin\;C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin;C:\Program Files (x86)\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn\;C:\Program Files\Microsoft SQL Server\150\DTS\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Users\cmaurice\AppData\Local\Microsoft\WindowsApps;
Mechanical APDL execution Command: mpiexec  -genvlist ANS_USER_PATH,ANSWAIT,ANSYS_HPC_PARAMETRIC_ID,ANSYS_HPC_PARAMETRIC_SERVER,ANSYS_SYSDIR,ANSYS_SYSDIR32,ANSYS222_DIR,ANSYSLI_RESERVE_ID,ANSYSLI_USAGE,AWP_LOCALE222,AWP_ROOT222,CADOE_DOCDIR222,CADOE_LIBDIR222,LSTC_LICENSE,P_SCHEMA,PATH,I_MPI_COLL_INTRANODE,I_MPI_AUTH_METHOD,I_MPI_FABRICS  -localonly -np 1 -env KMP_AFFINITY norespect "C:\Program Files\ANSYS Inc\v222\ANSYS\bin\winx64\ANSYS.EXE"   -dir c:\temp  : -np 1 "C:\Program Files\ANSYS Inc\v222\ANSYS\bin\winx64\ANSYS.EXE"   -dir c:\temp
