Yes, but now you have the LS-DYNA solver installed. Go to the Start Menu and under ANSYS 2022R2 LS-DYNA Student select LS-Run. Use that to submit a .k file to the solver.  Under that same folder is LS-PrePost that you can use to build a .k file of your model and look at the results.
Good luck!
