Cedrick Biellmann
The green object is the dielectric (FR4). Below this object you have a ground plane and inside the dielectric a strip line linked to the connector. The connector is a single conductor and only the little surface at the end in red (see schematic) is plane. So how I can define a waveport or a lumped port at the end of the connector?
