Daniel Shaw
Yes, failure at 20,000 cycles is probably due to low cycle fatigue, so the SN approach would probably not be appropriate.  However, the EN approach should be appropriate.  Why do you believe EN is not appropriate?  The low cycle curve shown in the plot extends well below 20,000 cycles.
