Guilin Sun
It is normal as when the parameter changes it is not the same device. The parameter changes can  create or avoid large diffration angles and resonance.
I usually suggest users to do several different sweeps to narrow down the better parameter range. Sweep is different from optimization.
PS: please write a new post everytime you have different questions from the first post.
