Erik Kostson
Hello
There is an error in the line:
*enddo solve is wrong and should be:
*enddo
solve
Another things is that the pol. direction is opposite in the 2.15 example while you have the same:
The polarization which is given by these lines and in combination with the material properties given (which are relative the element system):
local,11                        ! Coord. system for lower layer: polar axis +Y
local,12,,,,,180                ! Coord. system for upper layer: polar axis -Y
type,1 $ esys,11
amesh,1                         ! Generate mesh within the lower layer
type,1 $ esys,12
amesh,3                         ! Generate mesh within the upper layer
Erik
