Miguel
As far as I can see yes, that is the only difference. Now I am running another try with some changes I introduced in the joint definition (I changed stops to locks and set a broader range to avoid interference with the contact scoped to the same part) but it takes a while to see if it works... I´ll let you know when it´s finished (if it does) and will also try your suggestions. Thanks again for them
