Dear Howard,
Thanks for your reply. I deleted the EMB_Icepak Design and followed the steps in the Ansys video (
) again until I should assigne a thermal EM loss. I did not use this project but inserted its path. As you can see on the screenshot below no source design or solution is found even tho the Maxwell design is in the same project and has been analyzed.
If you have any idea what the problem could be I am very interested.
Thank you and with kind regards
Lukas
