Steady isn't likely to work well, but if you know roughly where the three fluids will be then the Patch option is a good way to speed up reaching the equilibrium condition.
Do you expect the three streams to intermingle whilst stratifying or do they remain separate all the way through? I ask as VOF assume you're tracking the free surface so the model isn't designed for diffuse fluid interfaces.
