March 9, 2023 at 7:23 pm
Thanks for your quick reply. I forgot to tell that i am using Ansys Workbench, so i don't have any skills in APDL.
What i meant above was that i don't know how to use my data for the material model. After choosing the Drucker-Prager model in the engineering data, workbench asks for data like uniaxial tension/compression strenght and the biaxial compression strength. If i choose the additional softening option for the DP Model, there will be more necessary data. For all these points i don't know how to transform my data from the compression test into the necessary data for workbench. Generally i don't know how to use this material model in workbench and i couldn't find any help in the internet.
Maybe you can give me some advise how to work with it.
Thanks a lot
Max
