March 10, 2023 at 2:39 am
I increase the timesteps to 300 seconds. Alos the condtions I put earlier are not working Error: expression not valid. I changed the condtions to IF (StaticTemprature>300[K], 0.0446[kg/s],0[kg/s]) and plotted the results. The surface tempraure of the wall increases linearly. I think the issue is the StaticTemprature Condition as it solely depends on mass inlet which does not increase to above 288[K]. How should I write the condition if I want the wall temprature (Part 1:003) not to exceed 300[K]
