DrAmine
Do you want to get the wall clock time for injecting the particles? Are you injecting 100 particles at the same time? You can use a small journal which will create a variable, store the time there, inject 100 particles, create another dummy variable and store the time again and then you subtract both to get the time. Other direct way is to use the "benchmark" command.
