DrAmine
You require Scheme to do that or if you already utilize it work with PyFluent.
But is the Time Information under /parallel/timer usage not yet enough for you?
The other command  is: (benchmark '(ti-menu-load-string "command to be exectued in Fluent in TUI language"))
