Jean-Yves Tillier
In workbench I can record a journal from File -> Scripting menu, however it does not record the operations executed within the ANSYS meshing interface, only the operation done in workbench: this is not what I need.
In the ANSYS meshing interface, I see a "Mechanical Scripting" tool but no syntax is documented for executing the operations or scripting.
Can you specify if is possible to script the meshing methods and execute operation in ANSYS meshing in batch instead of using the interface?
Any example of journal for ANSYS Meshing methods available?
