Divya Giri
Hi Vinayak,
Thank you for explaining that. I need to generate a 3D crack( with some length, depth, and thickness) into a model and simulate the model to compression and buckling in the presence of that crack. So, I assume the arbitrary crack method would help me get that.
I also went through the Ansys help document but it hasn't mentioned how can I create another surface body. Could you please elaborate more on what you said 'Create a Surface in CAD that will be a Construction Geometry in Mechanical'? That would be really helpful.
Thank you in advance.
Best Regards,
Divya Giri
