March 15, 2023 at 12:08 pm
Hi Rob thanks.
I would normally do more research and begin with simpler geometry first however this is a simple analysis for a project Im working on which I need to complete ASAP.
If I ignore the air around and only study the impact of the exhaust heating the tapered section , which areas would I used thermal coupling and how would I ensure inlet conditions= outlet during the transient analysis to see the overall het transfer to the fluid in a closed loop.
