If you are assembling parts at 280C then want to monitor the creep as it cools down, both the material reference temperature in the CTE definition and the environment temperature should be 280C so that there is zero strain at 280C at the beginning of the simulation.
In that case, step 1 would not be a temperature load of 280C, it would be whatever temperature you want to cool down to.
