What information have you got on the reaction rates and effects? That's the starting point. In Fluent it's then either reactions or sink/source terms using a UDF to remove the two materials and add the crosslinked material.
Another starting point is to simply look at the fluid mixing: if the reaction is slow can you infer an effect based on how quickly the two materials mix?
