Hi Navya,
Apologies if you are not clear about my problem from the deatails I have provided. The first problem is solved to ceratin extent and I amsatisfied by the obtained results.
For the second problem, I have seen the videos that Ansys provides. I have designed the coil in magnetostsic solver first and then copied the model in eddy current solver and added the frequency. My aim is to see how the eddy currents induced in the metal object effects the inductance value of the coil.
The value obtained for inductance in both the cases comes out to be same. I am sharing the images of the model and setting I have used in Magnetostsic slover first. I hope you can be clear about it. MO is metal object and coil in the model, both made from copper
Thanks
Regards
Sushan
