CHIEH TING WANG
Hi! thank you with your reply !
the problem as you say to delete contact region solved the problem of 'Initialize',I am really appreciate!
but I met a new problem when I was using result I couldn't find the surface that i set how could be?
By the way I stilled used 'surface from edge ' to create the plane,should I suppose to create rigid body?
