Nikhil Narale
Which multiphase model are you considering?
"RSM also has some drawbacks" : Would you mind elaborating a bit.
You may also want to explore DES turbulence model, which is compatible with Mixture and VOF multiphase model. DES resolves the large-scale turbulent motions using LES and models the smaller, unresolved turbulence using RANS.
Thanks!
Nikhil
