Aras karimi
Hi Dear Nanda,
This type of text file format is for the case that the 3D geometry does not have distortions on its surfaces, in which case we can put its Z column in the text file as zero and easily open it in Design Modeler.
But my 3D geometry has distortions and roughness on its surfaces, which usually cannot be considered as zero column in the text file.
How can I convert XYZ data from this geometry to solid geometry in Design Modeler ?
Best regards
