Hi Peng,
Thank you for providing more information. Correct me if I am wrong, my understanding is that you want to obtain the “expansion for fom” results for all sweep parameters after the sweep is completed. In that case you will have to record this result during the parameter sweep as shown below or using the addsweepresult script command:
Then you can use getsweepresult script command to get these results. It should also show up in the GUI in results. Please let me know if you have more questions.
Amrita
