Hi M. Rojas,
It looks like that the error is associated with the memory size available in your computer. You can increase the memory of your computer and if this is not possible, you can simplify the model. For example, you can use shell elements instead of solid elements, or you can use larger element sizes to mesh your model. Also, try varying the mesh density to have small elements only in critical regions.
