Venkata Subramanian M
Warning: the updated model uses a different length unit than the original. Please verify the length and sizing value of objects in the tree outline and reset them for the modified model.
Warning: one or more objects may have lost some scoping attachments during the geometry upadate. You can identify these tree objects by filtering the tree using the scoping options set to partial.
Error: A mesh could not be generated using the current meshing options and setting.
Error: one or more surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology.
Error: one or more entities failed to mesh. The mesh of the bodies containing these entities may not be up to date. However meshing might be successful on the other entities.
Warning: the mesher did not generate any nodes. All geometry may have been defeaturrd away.
All these are warnings and errors i got sir.
If i set element size as 0.3 mm it running and not finished. Is it take longer time.
The length of the spiral surface is 500mm and the starting diameter is 15.8 and ending dia is 20mm
