Muhammad Rizky Pratama Hakim
Dear Ilham,
A floating point usually occurs because the courant number is exceeding the limit, thus stopping the solver to continue solving the problem. I already tried to do the simulation and I did not find the floating point, the simulation worked. I guess you should try to check the setup again, especially in multiphase Volume of Fluid (VoF) setup, methods setup, boundary conditions setup, and initialization setup which has the further step to do, a patch set up to define initial conditions of the mercury and the air. The initialization process is very crucial for the transient simulation.
