Chavdar
Hi Gluo,
Please excuse me, maybe my question was not clear enough.
I meant, what is the interpolation method when using the python interface to export the field on a regular grid : https://aedt.docs.pyansys.com/release/0.6/API/_autosummary/pyaedt.modules.AdvancedPostProcessing.PostProcessor.export_field_file_on_grid.html
If it is the same interpolation method then my question is: Does this type of interpolation preserve the Maxwellian properties of the fields (divergence of the B field should be zero and curl should be zero in points where there is no current density)?
Chavdar
