March 25, 2023 at 3:26 pm
I tried Convective cooling on the outer surfaces only and I found that copper is so great of a conductor of heat that the temperature throughout the model goes down so rapidly that it matches the air temperature in seconds. If you are simulating an oven with a controlled cool down ramp, you have a good load definition.
