Praneeth
Hi Simay,
Thank you for reaching out and your patience is much appreciated.
It looks like your setup is not correctly set for the antenna simulation. As you are a new user, it is suggested to go through the getting started guides (GSG) which can help you with a correct simulation setup. Go through - probe fed patch antenna GSG to learn the detailed steps available in the Help menu. Alternatively, you can access the online version of this GSG here - Ansys Electronics 2023 R1 - Set Up the Project
Additionally, you can also go through antenna examples to get hands-on experience with antenna simulation in Ansys HFSS.
Best regards,
Praneeth.
