pawel_rek
Normal Stiffness Factor = 1 is basically default (what ANSYS calculates). Try reducing it to 0.1 and check convergence. Depending on a mesh quality try also different "Detection Methods". If you're using newer ANSYS release you can also play a bit with "Normal Lagrange" formulation. Hope it helps.
