April 4, 2023 at 1:18 pm
I can explain
I have only two data
- Inlet temperature 301.05 k
- Relative humidity
Here have a hexagonal shape pipe 125mm length
silica gel absorb the water vapour in air.
here I am used
steady
model was k epsilon- RNG - standard wall treatment
in material
Spicies transport on make mixture of water vapour + air
in spicies transport- volumetric on and inlet diffusion on
i don't know that right or wrong
please correct me
I objective was outlet temperature will be higher than inlet temperature and outlet RH will be decrease compared to inlet RH
REGENERATION TEMPERATURE- 328.15
pipe made of silica gel
