Andreas Koutras
Hello, do you mean how to perform a static analysis after an explicit analysis?
To switch from explicit to implicit, the option IMFLAG<0 of CONTROL_IMPLICIT_GENERAL can be used. However, it may be challenging for the implicit analysis to converge depending on the level of prior damage and various analysis settings. Applying the load quasi-statically using explicit analysis will be more promising
