I re-simulated several times there is still nothing. On the Linux terminal I have the following messages :
WARNING - Filename 'PolarFire_IBIS_AMT_SR_Model.ibs' should be lowercase
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'P'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'F'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'I'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'B'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'S'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'A'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'M'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'T'.
ERROR (line 5) - File_name 'PolarFire_IBIS_AMT_SR_Model.ibs' contains an upper case character 'R'.
... Reading PolarFire_IBIS_AMT_SR_Model_100.ami
WARNING - Filename 'PolarFire_IBIS_AMT_SR_Model_100.ami' should be lowercase
... Checking PolarFire_IBIS_AMT_SR_Model_100.ami for Implicit AMI Version 5.0 Compatibility...
ERROR - AMI_Version "6.1" is not valid
... Done Checking PolarFire_IBIS_AMT_SR_Model_100.ami
... Done Reading PolarFire_IBIS_AMT_SR_Model_100.ami
... Reading PolarFire_IBIS_AMT_SR_Model_150.ami
WARNING - Filename 'PolarFire_IBIS_AMT_SR_Model_150.ami' should be lowercase
... Checking PolarFire_IBIS_AMT_SR_Model_150.ami for Implicit AMI Version 5.0 Compatibility...
... Done Checking PolarFire_IBIS_AMT_SR_Model_150.ami
... Done Reading PolarFire_IBIS_AMT_SR_Model_150.ami
... Reading PolarFire_IBIS_AMT_SR_Model_float.ami
WARNING - Filename 'PolarFire_IBIS_AMT_SR_Model_float.ami' should be lowercase
... Checking PolarFire_IBIS_AMT_SR_Model_float.ami for Implicit AMI Version 5.0 Compatibility...
... Done Checking PolarFire_IBIS_AMT_SR_Model_float.ami
... Done Reading PolarFire_IBIS_AMT_SR_Model_float.ami
It wouldbe better to send you the project with the IBIS models that I took directly from the microchip's website.
