Sahil Sura
Hello Umut Can Gölbaşı,
Any one of the moments or the bearing loads would work for the problem but you need to make sure about the hand calculations for equating moment and loads.
I tried replicating the problem with a similar but simpler geometry and the results are as follows,
When applying the loads and boundary conditions I tried applying them as components rather than as vectors to get an essence of the situation.
There will definitely be some differences in results because of assumptions for boundary conditions but we've to choose between the % allowance and the boundary condition.
The following references may serve as helpful for more insights-
Moment (ansys.com)
Bearing Load (ansys.com)
Hope this helps!
Thanks,
Sahil
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
