April 5, 2023 at 3:07 pm
Hello Raghavendra,
I recommend you to use the Multizone controls in fluent meshing mode using the water tight geometry guided workflows and use the multizone meshing technique . I am attaching the user guide link in which it is clearly mentioned on how to perform this along with some example of a geometry on a particular plane. kindly go through this in detail. It should solve your problem.
3.13. Adding Multizone Controls (ansys.com)
3.14. Generating the Multizone Mesh (ansys.com)
If you are not able to access it kindly use this link
Using Help with links (ansys.com)
Thanks
Chaitanya NatrajĀ
