April 5, 2023 at 6:26 pm
Actually...Try the following option to see if you are able to get the Mechanical interface to open..
Linux
If you are running Workbench on Linux and experience problems at startup or with the user interface or graphics displaying correctly, and you are running in accelerated graphics mode, you may need to relaunch Workbench using the -oglmesa
flag to activate software rendering:
runwb2 -oglmesa
If Workbench detects that graphics problems are causing crashes, it automatically switches to software rendering. Workbench also uses software rending mode by default when running on a remote display, or on a local display if the hardware does not appear to be accelerated.
To revert to accelerated graphics mode, launch Workbench using the -oglhw flag:
runwb2 -oglhw
