Hi Rajat,
You can set the PML profile using the set or setnamed script commands. For example, if you want to set the PML profile to stabilized, you can use the following code:
setnamed("FDTD","pml profile",2);
The third argument is what decides the PML profile. 1 is for standard, 2 is for stabilized, 3 is for steep angle, and 4 is for custom. Thank you!
Amrita
