Perhaps the finer mesh is causing a softer contact stiffness response? What happens if you turn off contact stiffness updating (as a test)?
How does the bolt adjustment compare to the contact penetration in the primary load path of the bolt load?
How does the bolt working load compare to user defined bolt pretension?
