Andreas Koutras
Could you increase the contact thickness a bit further so that there is some initial penetration throughout the surface. To modify the contact thickness, you can use SAST or SBST on *CONTACT. I tried it with tiebreak OPTION=11 in MPP and seems to be working. Running a test with a flat contact surface will help confirm this.
