Vinayak Vipradas
Can you confirm that the OUTRES command includes outputting stress data to rst file? Did you issue the "SET" command to point to a result set before you plot? When distributed solver is used it is required to issue the SET command. Otherwise only some of the results are available in the database.
Vinayak Vipradas
