aMIT SINGH
My problem statement is laminar flow. I needed the finitte rate chemistry to to solve the problem. The issue is that once I take molar concentration and temperature foutput from fluent and calculate the net kinetic rate of reaction using same parameters used in fluent simulation. I can not match these two values (my hand calulations and fluent output of kinetic rate of reaction). Can you suggest something which might be the cause of this dicrepency.
